RCA 6K3 Preliminary Capacitor/Resistor Research
Mike,
Without a tester, the best I can do is to swap the tubes for a known good one which I am willing to order.  I will try to disconnect the screen grid on the 6A8 tonight to see if that makes a difference on reception as Rod has suggested.  I am tempted to order two since swapping in the 6A8 from my 37-620 did not make the problem go away.
Is a short on the screen grid of 6A8 a common failure?  It would seem odd otherwise that I would just so happen to have two that exhibit this problem.  I will double-check also that swapping just the 6A8 or just the 6K7 does not impact the results.
Best wishes,
Roy
RE: RCA 6K3 Preliminary Capacitor/Resistor Research - by glyphmon - 05-26-2026, 12:14 PM
There are currently 1949 online users. [Complete List]
» 1 Member(s) | 1948 Guest(s)
