06-10-2026, 02:22 PM
Chas
Our tastes in waveform seems to be similar, despite you not being me
Looks just fine.
Dconant
This is what I wanted to see. The waveform, as you can see, is symmetrical. Not the ideal sinewave, but good enough and symmetrical; however if you look at the old pictures, you could see how the lower half narrows towards the bottom, kinda like a long "V". This is what your old scope does to the waveform.
This is why I asked you to take it with the new scope, as this one should give you some faithful representation.
As for "so much I don't understand", for the radio troubleshooting most is not even necessary, but if you have an inquisitive mind, take the manual and play with it a bit, or watch a video(s) which, I think, should exist.
The scope is digital, so the triggering is obviously more powerful than simple level setting in old analog scopes. You could set rising/falling edges, delays, filtering, possibly some logic conditions on which to trigger; you could do some digital measurements, you could possibly do some Fourie analysis and math...Save and recall waveforms and many other things.
The manual is your friend.
https://cdn-aorpci9.actonsoftware.com/ac...ide_EN.pdf
The Pattern Triggering is very cool.
PS. Do the probe compensation routine, that is important.
Looks just fine.
Dconant
