Threads: 291
City: Wilsonville
State, Province, Country: OR
Back to work on the Gilfillan. I did some grain filling using Timbermate (walnut color). Made a slurry up with some additional water (its water soluble) and spread it around the walnut veneer. I then used a slightly damp paper towel to "sand off" the excess. It always looks like the grain is totally filled when I finish this, but it never is. After a coat of medium brown toner and several coats of clear gloss lacquer in my "spray booth" its starting to look better. I did paint the inside of the grill cut out with a flat black acrylic which will get glossy with the lacquer. Still needs a few more coats and then I'll put the black lacquer on the sides and bottom.
RE: 1935 Gilfillan 43-A - by klondike98 - 07-17-2026, 02:46 PM
| Hello Rob,
I agree with you—I have one here at my house that I need to check out. It’s way over-engineered just to make...radiorich — 11:05 AM |
My Atwater Kent 84
| Well getting around to restoring my AK84. Mike was a big part in me being able to snatch this one a few years ago. I won...462ron — 10:57 AM |
| The engine is a B&S 23 inch cast Iron holds 2 quarts of oil. The Generator is a 4 pole 1800 rpm mine was made in 195...David — 10:51 AM |
| Dale: Modified topic as suggested. It is not for a specific project. I found it in a box of stuff I recently purchased...GRG — 10:34 AM |
That looks a lot like an aircraft connector of some kind ...
That is a MIL-5015 style connector, used in a wide v...DaleHCook — 10:19 AM |
| I would suggest changing the topic from "P45-6365 Universal Transformer" to "45-6365 Universal IFT."...DaleHCook — 10:08 AM |
| And life just keeps getting more complicated. By dconant.
Dittos'Jimradio — 08:01 AM |
| hello david,
There are currently 1181 online users. [Complete List] » 3 Member(s) | 1178 Guest(s)
