08-08-2026, 08:16 PM
I'm continuiong the discussion on the GE 210 from the "August Finds and Losses" to here where it is probably more appropriate. Mr. Fixr, I have done the resistance measurements for the first and second AM IF transformers. They conform to the given values of 15 ohms on both the primaries and secondaries. I recleaned the band switch and measured the continuity thereof and contact is securely made, both AM and FM. I found a connection from the Variable cap to the antenna that was loose and I re-soldered. Very little change in sensitivity. I will probably look at performing an alignment tomorrow. I rarely align a radio if the tracking is only off a little, but that seems to be the next step. Thanks to all who have contributed to finding an answer to this problem. Joe
