Field Coil repair question
Hi,
I believe I can answer your question about C5 and C15. Look at the apparent connection point and follow the wire up and out of the block where it attaches to a ground lug. Now look at the schematic and locate both capacitors. You'll notice that they are each connected at one end to ground. There might be a ground buss running through the block that connects to the ground lug. You'll also notice on the schematic the value of C15 is 0.6mfd or two 0.3mfd in parallel.
Field Coil repair question - by Hamilton - 09-19-2026, 11:14 AM
RE: Field Coil repair question - by DaleHCook - 09-20-2026, 08:57 AM
RE: Field Coil repair question - by Jim Dutridge - 09-20-2026, 11:01 AM
Hamilton - by Hamilton - 09-22-2026, 11:50 AM
RE: Field Coil repair question - by DaleHCook - 09-22-2026, 12:05 PM
RE: Field Coil repair question - by MrFixr55 - 09-22-2026, 08:13 PM
Hamilton - by Hamilton - 09-27-2026, 03:24 PM
RE: Field Coil repair question - by RodB - 09-27-2026, 08:57 PM
RE: Field Coil repair question - by Hamilton - 10-01-2026, 04:00 PM
RE: Field Coil repair question - by Arran - 10-03-2026, 06:13 AM
