10-19-2006, 12:57 PM
One method would be to just use a modern axial cap under the chassis and wire it in place of the existing cap. Don't wire it across in parallel - you don't want the old cap part of the circuit any more.
Another option for rebuilding the wet aluminum can capacitors can be found on Chuck's website. Either way you'll still have the original appearance on top, but if you rebuild the cap, you'll have an original appearance on both sides of the chassis.
http://www.philcorepairbench.com/tips/svctip46.htm
Good luck!
Bill
Good luck!
Bill
Sent from my Pentium II on the AT&T Dial Network
