Philco 90 High Resistance Antenna Coil?
Hello 7etatdef
Thanks for the reply...I measure 11.1 ohms resistance from chassis ground and the ANT post, so I'm assuming no open. Is this ok or too high? If it is an antenna coil issue, I'm not sure if I want to attempt to pull it out and check or rewind it. This especially if you think the problem is worse than that.
If as you say, if the set doesn't care where you connect the antenna, can I keep it on the RF grid? (BTW...The set is one with one #47 tube)
Thank you again for your reply!
Joe
Philco 90 High Resistance Antenna Coil? - by Joe - 02-04-2012, 02:39 PM
Re: Philco 90 High Resistance Antenna Coil? - by Joe - 02-05-2012, 09:16 AM
There are currently 3439 online users. [Complete List]
» 1 Member(s) | 3438 Guest(s)
