07-06-2012, 11:23 PM
Well first fix your signal generator, probably just needs a shot of Deoxit 5. Check accuracy with a frequency counter (with modulation off.) The least possible signal should be used when performing an alignment. Measure AC voltage at voice coil. An analog meter or VTVM is best. You can sub a 4 ohm resistor for the speaker if the noise bothers you.
