Candohm replacement
Recapped a 42-322.  Part #43 was a multi-section 20, 20, 10 uF (red, yellow, green w/ black common wire) electrolytic cap. I wired the negative leads together as the black common and the positive leads to the red, yellow and green wires respectively.  Did I get the polarity right?
[Image: https://www.dropbox.com/s/siqnuvnlc3trnc....jpg?raw=1]
[Image: https://www.dropbox.com/s/ckazdphd7vfl59....jpg?raw=1]
[Image: https://www.dropbox.com/s/1dxql2due9iimy....jpg?raw=1]
Reason I ask is that I only measure -1vDC between the common lead and the point where I should see 100vDC.  Rectifier tube filaments glowing (don't have a tube tester), field coil measures ~500ohms, dim bulb power up went OK.  New 35Z3 on order but your thoughts on other next steps I should consider would be helpful.
Thanks!
Bob
Candohm replacement - by klondike98 - 01-05-2013, 04:33 PM
RE: Candohm replacement - by codefox1 - 01-05-2013, 05:04 PM
RE: Candohm replacement - by morzh - 01-05-2013, 06:10 PM
RE: Candohm replacement - by klondike98 - 01-05-2013, 06:39 PM
RE: Candohm replacement - by Arran - 01-05-2013, 10:35 PM
RE: Candohm replacement - by Phlogiston - 01-05-2013, 11:26 PM
RE: Candohm replacement - by klondike98 - 01-06-2013, 02:57 PM
Electrolytic cap polarity question-update:Its alive - by klondike98 - 01-17-2013, 11:33 AM
There are currently 2000 online users. [Complete List]
» 1 Member(s) | 1999 Guest(s)
