As long as the center hole is small enough that you can mount the voice coil and spider to it it should work, do those have a foam or a paper hinge/surround? Or is it rubber? I too have known about the acetone trick for removing a glued on cone, actually lacquer thinner works just as well. You don't really need to let soak as long as 15 minutes, 5 to 10 is usually sufficient. You can use some strips of film negative or some other thin yet stiff plastic to shim between the voice coil and the pole piece.
(This post was last modified: 01-23-2013, 01:45 AM by Arran.)
RE: Philco 15DX restoration - by Arran - 01-23-2013, 01:42 AM
There are currently 1596 online users. [Complete List] » 1 Member(s) | 1595 Guest(s)
