01-26-2013, 11:34 PM
Propflux, if the can is like the IF can in the 42-322 I'm working on, there is a brass bar on the bottom of the can that holds the coil in the can. You have to pry up the brass tab and release it from the can on both sides to be able to lift the can. Alternatively you can unsolder all the wires that go into the can and then carefully lift the can, coil and all, by pulling the wires through the holes in the chassis. With the can assembly out you can then more easily pry off the brass bar holding the coil inside the can. I don't have the best picture of this but here's what I do have. You can see the red circle points out the slot in the can that the brass bar fits into.
Bob
[Image: https://dl.dropbox.com/u/54621529/IFcoilCan.jpg]
Bob
