02-27-2013, 11:41 AM
Silly question, are there one or two leads coming off the signal generator? This thing didn't come with any leads when i bought it and from what I saw on Youtube there should only be one lead?? When I adjusted the first three tuners (#24,#25,#28) I only used one lead. Sorry about that video, I'll try to get a closer view of the signal generator tonight after work, I want to make sure that I'm using the signal generator properly.
Jerry, when you say that I may not have the oscillator working properly, do you mean the:
- Oscillator Transformer (#16)
OR
- Detector Oscillator (#5) also called the Tuning Condenser Assembly
Also, I just remembered something, when I first started restoring this radio, there was no antenna wire...I added a wire per the schematics and connected one end to the ANT clip on the top/rear of the chassis and the other end I soldered to the Antenna Transformer (#3) from the underside of the chassis. I'll have to go back and double check that I used the correct tab on the Antenna Transformer, who knows, maybe that’s the problem right there? I'll let you know.
Thanks again for your help Jerry.
OR
