Philco 650 Rectifier tube bright!
morzh is right if you didn't replace the e-caps then one or more of them could be shorted and that will put a serious load on the 80 tube and the power trans.
Looks like there are 3 e-caps on the set a dual #77 on the schematic which is an 8uf and a 10uf, and a single #78 which is an 8uf. All of these can be replaced with 10uf modern caps @ 450v.
Replace those caps before trying to power the set again, also if I were you I would ohm out the power trans to make sure it wasn't damaged at some point.
Schematic here:
http://www.nostalgiaair.org/PagesByModel...013824.pdf
If you need a clearer copy PM me.
-Keith
Philco 650 Rectifier tube bright! - by ewalters - 03-20-2013, 08:42 PM
RE: Philco 650 Rectifier tube bright! - by Keith - 03-22-2013, 01:03 PM
RE: Philco 650 Rectifier tube bright! - by morzh - 03-22-2013, 08:53 PM
RE: Philco 650 Rectifier tube bright! - by Keith - 03-23-2013, 12:48 PM
RE: Philco 650 Rectifier tube bright! - by morzh - 03-23-2013, 03:05 PM
