Veneer repair and finish advice for Philco 14MX
I' m sure I can get the trim made, that's no real worry. I found the same ad and saw where it said black trim. I have a bigger problem though. While looking it over, I noticed that the side panels have warped. If I put a straightedge across them and there is a concave bow to them of about 1/8" on one side and a little more on the other. I have the sides strapped and clamped as flat as I can get them for now and I'll leave them for several days in the hope the panels will flatten out somewhat. If not I may have to put some sort of bracing, possibly like oak or hickory, and screw them to the inside to pull them flat, or get new panels made by someone who is a professional cabinet maker. The bracing would detract from the originality of course.
RE: Veneer repair and finish advice for Philco 14MX - by Groundhog74 - 06-01-2013, 06:36 PM
That's the Philco rf trap in a foreign radio. Resonant somewhere around the IF, it's a short to ground. You can just rep...RodB — 08:10 PM
I can't believe I missed this little critter when replacing the electrolytics. Wasn't much of him left, he crumbled wh...klondike98 — 06:39 PM
Thx Richard. Arran, the 0.02 caps in mine are also 100v. As I mentioned the original paper tube is just a little small...klondike98 — 01:02 PM
New find. 91X code 225
Nice job there. A very distinguished looking radio. Would like to see a photo when done with added light. Paul B.Paul Philco322 — 12:27 PM
Thanks all. Yeah, I was motivated to do this one and they're generally easy to work on. I don't do a lot of early-'30s...pdieten — 10:22 AM
Hello Bob, What nice looking set it looks like a Emerson that I have you did great job with the two Electrolytic cans ....radiorich — 02:04 AM
Hello Paul, Well, done it looks great ! Sincerely Richardradiorich — 01:55 AM
Congratulations, Paul! That was quick...you made short order of that chassis restoration! And no coils to rewind...bonus...NostalgiaRadioTime — 01:07 AM
Bob; I was thinking the same with that 150 ohm resistor, put a larger value replacement in it's place to compensate f...Arran — 01:02 AM
And the chassis is all done, all caps and bad lamp wiring replaced, power switch repaired and in place, dial string tune...pdieten — 12:37 AM
