08-17-2013, 11:14 PM
Also keep in mind that the #68 cap has its (+) - PLUS terminal to the chassis and NOT the (-) Minus. Many people make that mistake.
It also helps if you do not use the word "ground to somewhere else". You van ONLY ground to the Ground (or you can call it "chassis"). Otherwise it is not grounding. But of you call it "grounding" it kinda sets your mind to try to connect it to GND whereas it might not be connected there at all. Using right terminology disciplines the mind and eventually prevents you from connecting things to where they do not belong. Like to the Chassis all the time.
