08-21-2013, 11:37 AM
That depends on which chassis you have. If its just a 42-1008 then the part number is 32-8129 that has 2 seperate filament windings along with the rectifier filament. If its a code 121 or 122 then the transformer was changed to part number 32-8217 and only has 1 filament winding along with the one for the rectifier.
Throwing some numbers together, and figuring that you might have the code 122, I would say secondary of 350-0-350 volts at around 220ma. Rectifer filament 5v @ 2A and the other filament of 6.3v @ 2A minimum. I might be wrong on these figures and I'm sure others will chime in.
