40-190 chipped veneer
I don't think you can make it worse. It all depends on what you can live with. No matter what you do, the repair will be somewhat visible. I sent some veneer, but it may be darker than you need. I like codefox's idea. The method I have used is to take a piece of paper and a pencil and make an etching, then cut veneer to fit. Fill in the area as best as I can with some veneer, trying to match the missing places. Glue it in. If it's not level, I lightly sand the new veneer. Then I smear some Timber Mate colored wood filler over it and wipe off the excess. After that, I spray some toner or clear lacquer over the spot.
Timber Mate is a product now being carried by Woodcraft stores. It's imported from Australia and guys who lay wood floors use a lot of it. It's water soluble, comes in a bunch of different colors and works better than any wood filler I've ever used. You can thin it with water, and if you mess up, a wet rag will allow you to start over.
If you don't feel comfortable doing it, call a pro.
40-190 chipped veneer - by fossilexpress - 09-02-2013, 10:07 PM
RE: 40-190 chipped veneer - by Jamie - 09-03-2013, 08:08 AM
RE: 40-190 chipped veneer - by fossilexpress - 09-03-2013, 12:33 PM
RE: 40-190 chipped veneer - by Jamie - 09-03-2013, 01:31 PM
RE: 40-190 chipped veneer - by EricS - 09-03-2013, 02:04 PM
RE: 40-190 chipped veneer - by Arran - 09-03-2013, 10:11 PM
RE: 40-190 chipped veneer - by fossilexpress - 09-03-2013, 10:18 PM
RE: 40-190 chipped veneer - by codefox1 - 09-04-2013, 12:00 PM
RE: 40-190 chipped veneer - by Jamie - 09-05-2013, 11:56 AM
RE: 40-190 chipped veneer - by fossilexpress - 09-05-2013, 08:31 PM
RE: 40-190 chipped veneer - by EricS - 09-05-2013, 11:14 PM
RE: 40-190 chipped veneer - by fossilexpress - 09-05-2013, 11:36 PM
RE: 40-190 chipped veneer - by Arran - 09-06-2013, 01:27 AM
RE: 40-190 chipped veneer - by fossilexpress - 09-15-2013, 11:42 PM
RE: 40-190 chipped veneer - by Jamie - 09-16-2013, 07:10 AM
RE: 40-190 chipped veneer - by EricS - 09-16-2013, 09:51 PM
RE: 40-190 chipped veneer - by EricS - 09-18-2013, 09:22 PM
RE: 40-190 chipped veneer - by fossilexpress - 09-19-2013, 12:29 AM
RE: 40-190 chipped veneer - by EricS - 09-19-2013, 07:18 PM
There are currently 1923 online users. [Complete List]
» 1 Member(s) | 1922 Guest(s)
