Sorry just looked at the diagram for your set. I thought it was a set with a power trans and SW. You got the economy model with a voltage doubler and series strung heaters.
http://www.nostalgiaair.org/PagesByModel...013614.pdf
Hum
Have much do you hear? A lot or just a little?? I would suspect that this set may have a little bit hum just from it's design.
Osc
Check the pins on the tube and socket. I'm presuming that you've replaced all the paper caps? C 403 or the mica C405 could be your culprit. Did you measure the resistors when you had the caps disconnected??
48-1262 - by ke5yum - 10-08-2013, 01:14 PM
RE: 48-1262 - by klondike98 - 10-08-2013, 04:05 PM
RE: 48-1262 - by BrendaAnnD - 10-08-2013, 04:09 PM
RE: 48-1262 - by ke5yum - 10-09-2013, 07:42 AM
RE: 48-1262 - by ke5yum - 10-22-2013, 07:56 AM
RE: 48-1262 - by Radioroslyn - 10-22-2013, 06:05 PM
RE: 48-1262 - by Radioroslyn - 10-22-2013, 06:48 PM
RE: 48-1262 - by ke5yum - 10-23-2013, 08:05 AM
RE: 48-1262 - by ke5yum - 10-30-2013, 07:57 AM
RE: 48-1262 - by Radioroslyn - 10-30-2013, 08:15 PM
RE: 48-1262 - by ke5yum - 10-31-2013, 08:02 AM
RE: 48-1262 - by Radioroslyn - 10-31-2013, 04:53 PM
RE: 48-1262 - by ke5yum - 11-01-2013, 07:50 AM
RE: 48-1262 - by ke5yum - 12-13-2013, 09:16 AM
RE: 48-1262 - by Radioroslyn - 12-15-2013, 01:08 PM
RE: 48-1262 - by ke5yum - 12-18-2013, 09:37 AM
RE: 48-1262 - by klondike98 - 12-18-2013, 10:03 AM
There are currently 1922 online users. [Complete List]
» 3 Member(s) | 1919 Guest(s)
