1936 60 alignment issues
Thanks for the replies. Got tied up with work last couple days..
I found one problem, i forgot to re-solider the ground strap to the tuner screw. After I fixed that I was able to peak the #12 and the Antenna trimmer to 600kc. I tried to get the HF two play ball but no luck. I had my signal gen set to 1400 the dial set to 1400, and nothing I tried could get the high side to align.
I'm not sure how to check if the oscillator is running through out the band, at the low end I can pick up some stations, so it seems ok, but nothing on the high end.
-Keith
1936 60 alignment issues - by Keith - 01-13-2014, 11:28 PM
RE: 1936 60 alignment issues - by morzh - 01-14-2014, 12:00 AM
RE: 1936 60 alignment issues - by BrendaAnnD - 01-14-2014, 12:46 AM
RE: 1936 60 alignment issues - by BrendaAnnD - 01-14-2014, 12:49 AM
RE: 1936 60 alignment issues - by Radioroslyn - 01-14-2014, 06:09 PM
RE: 1936 60 alignment issues - by Keith - 01-17-2014, 12:13 AM
RE: 1936 60 alignment issues - by Mondial - 01-17-2014, 12:35 AM
