Mystery Halson radio model 15 Pg 6 electrical issues
Threads: 310
City: Kings Park NY
This is the proper numbering of the L49B. The mains connect to terminal 3 and terminal 5 (being the 2nd and third pins), both are occupied by pins. I would assume that since I did plug it in and turn it on when I first bought it and nothing exploded that it was wired correctly unless it blew up in the past. there was no response when i turned it on. nothing lit up, nothing hummed, it was dead One thing is the main is not connected to the #1 pin. I cant tell from the ballast tube diagram you sent me which are active and which are dummy pins.
Image(s)
AC: 4 DC: 1
RE: Mystery Halson radio model 15?? - by OldRestorer - 01-23-2014, 04:10 PM
Hello Roy,
sincerely Richardradiorich — 12:45 AM
Richard,
Had grabbed it already but thank you just the same. I find myself wanting to find some way to block out the...glyphmon — 12:03 AM
Hello roy,
Sincerely Richardradiorich — 11:54 PM
Richard,
The Silvertone 2014 also is a transformerless set, so I am incorporating a 1:1 600 ohm audio isolation transfo...glyphmon — 11:37 PM
Did an alignment today which was interesting. IF alignment went great, almost all was already spot-on. Adjusting on th...glyphmon — 11:35 PM
While I'm waiting to wrap up the final steps on my wife's Silvertone 2014, I started disassembly on the next project. O...glyphmon — 11:07 PM
Hello roy,
Sincerely Richardradiorich — 10:50 PM
Safety caps arrived today. Soldered one in and had a successful first power-up. No magic smoke escaped and it tunes in...glyphmon — 09:53 PM
There are currently 1736 online users. [Complete List ]» 2 Member(s) | 1734 Guest(s)
