Philco model 70 rebuild - by Tim P.
Threads: 94
City: Annapolis, IL
State, Province, Country: USA
I did some checks. I unsoldered the wire from the vol control to the coil to check more thoroughly. The coil checked out ok. I had 9.4 ohm on the ant side and 4.8 ohm on the tube side. The volume control is dirty on the ant side, but checks 5k on outside lugs. I think cleaning will fix. I did power up and clipped a wire on the unsoldered wire to the coil and had good volume, but it did not help the sensitivity. When I touch the wire back on the control, it drops the signal a lot, but still picks up. With no ant, tuning the radio to the higher freqs, it hits a spot where the microphonics come back with a lot of feedback - etc. I have pulled the tuning condenser to clean. The screws to the wires werent very tight. Any recomendations on cleaning this? I wonder of those wire contacts the rub the main shaft are the problem. What about washing the dial? Any condensers that could be damaged with water? Any advice appreciated.
This will be the thorough and final cleaning of the chassis before I reassemble for keeps. Yes, all tubes tested. I got no response moving my hand near the RF coil, only when I clip a lead where I mentioned.
Tim
RE: Philco model 70 rebuild - by Tim P. - by TV MAN - 02-18-2014, 04:15 PM
There are currently 1690 online users. [Complete List] » 1 Member(s) | 1689 Guest(s)
