Atwater Kent 84
Personally I wouldn't bother doing that with a tube as readily available as an 80. You can get a new 80 for $12 or good used for $6:
https://docs.google.com/spreadsheet/ccc?...0foD#gid=4
It won't be a globe but it won't require kludging in diodes and resistors under the chassis either. Keep your eyes open and you'll eventually find a good globe 80 on eBay, a radio meet, an old parts set, or a wanted ad. There is no shortage of globe 80's out there if you're patient.
I'd also measure B+ with a good 80 and then your weak one; often a weak 80 isn't that far off, depending on the parameters of the tube tester used.
If you're still determined you can use two 1N4007's and a wire wound resistor to drop the B+ down to what it measures with a known good 80 in the circuit.
Atwater Kent 84 - by fields 100 - 05-22-2014, 06:52 PM
RE: Atwater Kent 84 - by Eliot Ness - 05-23-2014, 09:31 AM
RE: Atwater Kent 84 - by TA Forbes - 05-23-2014, 09:47 AM
RE: Atwater Kent 84 - by morzh - 05-23-2014, 10:25 AM
RE: Atwater Kent 84 - by fields 100 - 05-26-2014, 01:35 PM
RE: Atwater Kent 84 - by Eliot Ness - 05-26-2014, 02:00 PM
RE: Atwater Kent 84 - by Phlogiston - 05-26-2014, 04:32 PM
RE: Atwater Kent 84 - by Arran - 05-26-2014, 09:57 PM
RE: Atwater Kent 84 - by fields 100 - 05-27-2014, 10:38 AM
RE: Atwater Kent 84 - by Mondial - 05-27-2014, 01:02 PM
RE: Atwater Kent 84 - by Eliot Ness - 05-27-2014, 01:13 PM
RE: Atwater Kent 84 - by fields 100 - 05-27-2014, 01:20 PM
RE: Atwater Kent 84 - by Eliot Ness - 05-27-2014, 01:33 PM
