Question on replacing the selenium rectifier in my tube checker
Hey gang, I have a heathkit TC-2 tube checker. I have replaced the caps and some off spec resistors. It has a selenium rectifier which id like to replace, its on the secondary of the Xfmr. My question is must I use a resistor in series with a new diode? I have hooked it up with test leads (1N5401) and it works OK without any resistance added, I am able to zero the meter and have some left on the trim pot. If I add a 100ohm i need to turn the pot full on to get the meter up to zero position.
I replaced one of these on my VTVM and had to use a resistor to drop the voltage but it was on the primary.....not sure what to do here....
The schematic shows a silicon diode symbol. Any ideas?
[Image: http://i818.photobucket.com/albums/zz105...bc3634.gif]
Question on replacing the selenium rectifier in my tube checker - by conroyp - 06-19-2014, 11:50 AM
