Philco 16B noise suppression circuit pot
Look like the original is probably a 2 Watt wirewound?
Under normal operation, the pot dissipates only 0.16 Watt, but at turn on its quite a bit more. Before all the tubes heat up, there is almost 500 V across the voltage divider, and the pot is subject to about 100 V. Calculating the power (100 x 100 / 10000 ), it is 1 Watt under those conditions, so to be conservative I would go with a 2 Watt replacement
RE: Philco 16B noise suppression circuit pot - by Mondial - 08-16-2014, 06:44 PM
There are currently 2283 online users. [Complete List]
» 2 Member(s) | 2281 Guest(s)
