46-480 Recapped now nothing.....
The problem is most likely something you did in your rework. Some common issues in no particular order:
-> New component soldered to the wrong place.
-> New component has the wrong value, for instance replacing a 10,000 ohm resistor with a 100,000 ohm resistor.
-> Solder blob that is shorting out two terminals that shouldn't be connected.
-> Electrolytic cap wired in reverse.
-> Bad (cold) solder joint on one of your solder connections.
Good luck.
Jon
46-480 Recapped now nothing..... - by KB3MDB - 08-27-2014, 10:47 AM
RE: 46-480 Recapped now nothing..... - by morzh - 08-27-2014, 11:42 AM
RE: 46-480 Recapped now nothing..... - by Eric T - 08-27-2014, 12:16 PM
RE: 46-480 Recapped now nothing..... - by PAradiogeek - 08-29-2014, 02:13 PM
RE: 46-480 Recapped now nothing..... - by EricS - 08-29-2014, 06:55 PM
RE: 46-480 Recapped now nothing..... - by Warren - 08-29-2014, 07:15 PM
