Fading signal- need help.
The link you gave is for an A-K set.
As for your problem, and your voltages:
You've either got a gassy tube, or a bad grid leak resistor. You're not seeing 800V or 1000V on that pin, those voltages don't exist in that set. What you're most likely seeing is 800-1000mV (I sometimes make that mistake with DMM's, too). Try swapping out the tube first, then start looking for resistors connected to it that have radically changed value.
Fading signal- need help. - by fields 100 - 09-28-2014, 11:34 PM
RE: Fading signal- need help. - by BrendaAnnD - 09-29-2014, 12:02 AM
RE: Fading signal- need help. - by fields 100 - 09-29-2014, 06:07 AM
RE: Fading signal- need help. - by fields 100 - 09-29-2014, 06:32 AM
RE: Fading signal- need help. - by Radioroslyn - 09-29-2014, 08:53 AM
RE: Fading signal- need help. - by Mondial - 09-29-2014, 09:11 AM
RE: Fading signal- need help. - by fields 100 - 09-29-2014, 11:39 AM
RE: Fading signal- need help. - by fields 100 - 09-29-2014, 02:27 PM
