Alignment.
OK, here is what I have done so far.Connected the counter to the osc. grid, all stations across the dial show the frequency of them +455K albeit being incorrect on the dial. So, I assume, that oscillator works fine. Prior to that,The 600 and 1500 had been aligned as per instruction procedure. The pointer was set .At that point all stations were grossly off on the dial.To bring the pointer to at least close position to the station I had to readjust the trimmer J, subsequently moving away from alignment, but that was the only option I had at the moment, unless there are some other ideas. I did not open the antenna coil can yet. Is it possible someone had been working on it or replaced with the wrong one?
Alignment. - by fields 100 - 09-29-2014, 05:50 PM
RE: Alignment. - by Radioroslyn - 09-29-2014, 10:33 PM
RE: Alignment. - by fields 100 - 09-29-2014, 11:36 PM
RE: Alignment. - by Radioroslyn - 09-30-2014, 07:36 AM
RE: Alignment. - by fields 100 - 09-30-2014, 08:21 AM
RE: Alignment. - by Radioroslyn - 09-30-2014, 06:03 PM
RE: Alignment. - by fields 100 - 09-30-2014, 06:53 PM
RE: Alignment. - by Radioroslyn - 09-30-2014, 09:20 PM
RE: Alignment. - by fields 100 - 09-30-2014, 10:51 PM
RE: Alignment. - by Radioroslyn - 10-01-2014, 08:07 PM
RE: Alignment. - by morzh - 10-01-2014, 09:00 PM
RE: Alignment. - by fields 100 - 10-01-2014, 11:04 PM
RE: Alignment. - by mikethedruid - 10-03-2014, 01:37 AM
RE: Alignment. - by fields 100 - 10-03-2014, 08:31 AM
RE: Alignment. - by AI2V - 10-04-2014, 12:07 PM
RE: Alignment. - by fields 100 - 10-05-2014, 07:13 AM
RE: Alignment. - by Radioroslyn - 10-05-2014, 10:11 AM
RE: Alignment. - by Mondial - 10-05-2014, 10:37 AM
RE: Alignment. - by AI2V - 10-05-2014, 12:05 PM
RE: Alignment. - by fields 100 - 10-06-2014, 07:30 AM
RE: Alignment. - by Mondial - 10-06-2014, 10:20 AM
RE: Alignment. - by fields 100 - 10-06-2014, 12:12 PM
