silvertone no/low volume need some advice
Hey gang,
finally got this project out and re-started working on it. It came out of my grandmothers house, 1930's sears silvertone 101.566--D. When I first check it out  it had very low volume....barely audible unless I hooked it to a longwire antenna, but tuned ok.
It has since been recapped, new resistors, power cord, tubes and im working a little on the cabinet too.
I have checked the speaker, volume control, tubes, with tester and by changing them as well, tuner coils, rf coil have continuity, I have not done a formal alignment but have turned the IF adjustment screws slightly with no improvement.
It tunes to local stations just fine, but the low volume is unchanged, I need some guidance on what to look at next.
http://www.nostalgiaair.org/PagesByModel...017529.pdf
[Image: http://i818.photobucket.com/albums/zz105...f878e0.jpg]
[Image: http://i818.photobucket.com/albums/zz105...fc1d92.jpg]
[Image: http://i818.photobucket.com/albums/zz105...4a2119.jpg]
thanks,
pete
silvertone no/low volume need some advice - by conroyp - 10-13-2014, 12:19 PM
