84B Restoration - update-Touchdown!
Question
John, I used a process I found on the net, although I'd have to search a bit to relocate it. (UPDATE- I found the thread, its our own Steve Davis' thread).  I take the barrel of a cheap Bic pen that is the right diameter and cut it to the right length.  With a hack saw blade I make a notch in both ends about 1/16 " so I can feed the leads through and then make two wraps around the tube (pen barrel).  I take the modern resistor and tack on buss wire (20 Guage if I recall corectly) such that the buss wire is soldered very close to the body of the resistor. This makes the buss wire the new leads for the restored resistor and of the right size and length to allow for the two wraps around the tube plus however much lead you need.  Slide the modern resistor into the tube, wrap twice at each end.   I then add a little solder to the two wrapped leads, just enough to flow solder to link the coils but be careful or you melt the tube. I plug each end with a little epoxy putty (the type that is a roll you cut and knead the two sections together.) I rough up the plastic with sand paper, paint with appropriate color and install.  In another radio I've made the type of resistor with the silver colored ends but in that case I made a mold out of epoxy putty and created the restored resistor with a mold technique....again, not my idea, but from a net search. Russ (Phlogiston) does outstanding restorations so I'll have to find the thread morzh mentioned.
RE: 84B Restoration - need advice - by klondike98 - 10-09-2014, 02:30 PM
RE: 84B Restoration - need advice - by morzh - 10-09-2014, 03:11 PM
RE: 84B Restoration - need advice - by klondike98 - 10-11-2014, 12:00 PM
RE: 84B Restoration - need advice - by klondike98 - 10-13-2014, 09:57 PM
RE: 84B Restoration - need advice - by morzh - 10-13-2014, 10:10 PM
RE: 84B Restoration - need advice - by klondike98 - 10-13-2014, 10:45 PM
RE: 84B Restoration - need advice - by klondike98 - 10-21-2014, 04:43 PM
RE: 84B Restoration - update-Touchdown! - by klondike98 - 10-22-2014, 01:24 PM
Grundig 5088
Grundig 5088
