Model 58 Schematic Question
I am working on a model 58 (I think - like the 57/58 schematic in Riders). It is all original - has not been touched. The filter capacitor is a 30-2013 A.  It has three lugs in a triangle: black paint at 12:00, Green at 8:00, and Red at 4:00. The problem is that the all original wiring does NOT match the schematics in Riders or Philcoradio.com.  In my radio the Red marked lug goes to the rectifier (filter input), and the Blue (or Green) lug to B+ (filter output). That is the opposite of the Change documentation for Capacitor 30.  I believe this has been discussed before, but I was unable to find an answer.
Should the filter input capacitor be 8mfd or 4mfd?  The schematic says 4mfd (blue), but in my radio it is 8mfd (red).
Model 58 Schematic Question - by davemc - 11-03-2014, 05:08 PM
RE: Model 58 Schematic Question - by Kekoa - 11-03-2014, 05:30 PM
RE: Model 58 Schematic Question - by David - 11-04-2014, 09:14 PM
RE: Model 58 Schematic Question - by davemc - 11-05-2014, 08:27 AM
RE: Model 58 Schematic Question - by David - 11-05-2014, 03:44 PM
Vlad; Yes it's very similar, Motorola obviously wanted to get the most use they could out of the dyes used to stamp o...Arran — 11:18 PM
Rod; I that 27 pf 1 kv capacitor you found a C0G ceramic cap or just a regular ceramic cap? A different topic but I t...Arran — 11:16 PM
Rogers Majestic R-646
Vlad; It's possible that the tar/bitumen using to pot the box may have lead to the failure of the transformer, either...Arran — 10:28 PM
Hi OSanders. another thing about the loop antenna is that it is directional. Try turning the radio in different direct...MrFixr55 — 09:19 PM
The 630v caps will do just fine. Physical size increases with capacity values and voltage. You don't have to replace 200...RodB — 09:09 PM
Help with Supreme 599
Good catch. The 589 is a better schematic but i dont understand how the voltage goes thru the meter to adj the line volt...daveone23 — 08:17 PM
Arron, Yes, I can see the differences in the interior design, but if you compare the schematics, they look very similar...Vlad95 — 06:57 PM
I am not sure how the loop antenna supposed to work but think I have figured it out. I had one lead on terminal 1 and go...osanders0311 — 06:56 PM
Thx Vlad.klondike98 — 06:54 PM
Hi Arran. I continue to disassemble and I see that the interstage transformer is completely beyond repair. It is placed...Vlad95 — 06:50 PM
