Philco radio from 1971 Ford F100
I probably don't understand where to connect the probes on the Volt Ohm Meter. I made the connections with the antenna wire unplugged. When it's plugged in the shield is grounded.
The local parts store owner was nice enough to let me try plugging in a new antenna. He also told me to make sure the antenna was grounded. After plugging in the antenna to the radio I connected a wire from the base of the antenna on the part that holds the antenna to the truck to a bare piece of metal. I got the same results with the new antenna that I got with my old one.
I have wanted to eliminate the antenna as a possibility before so once while I was getting reception I moved the antenna around (it has a spring base) and bumped the antenna and let it bouce around to see if there was a loose connection that would interrrupt the signal. The radio worked fine through it all.
I noticed yesterday and today with the new antenna connected that I was able to get a weak garbled voice at one place on the dial. It seems to be picking something up but not the strong AM station I usually can count on. I was sitting on the passenger side with the door open and reached out and touched the antenna and that made the radio quiet and when I let go it started making noise again so I know the antenna is doing something.
I really appreciate all of your help.
Steve L.
Philco radio from 1971 Ford F100 - by Guest - 12-02-2008, 11:17 PM
Re: Philco radio from 1971 Ford F100 - by exray - 12-02-2008, 11:50 PM
Re: Philco radio from 1971 Ford F100 - by Guest - 12-03-2008, 01:26 AM
Re: Philco radio from 1971 Ford F100 - by BILL - 12-03-2008, 03:59 PM
Re: Philco radio from 1971 Ford F100 - by Guest - 12-03-2008, 10:30 PM
Re: Philco radio from 1971 Ford F100 - by BILL - 12-04-2008, 11:16 AM
Re: Philco radio from 1971 Ford F100 - by Guest - 12-04-2008, 03:09 PM
Re: Philco radio from 1971 Ford F100 - by BILL - 12-04-2008, 07:51 PM
Re: Philco radio from 1971 Ford F100 - by Guest - 12-05-2008, 01:21 PM
Re: Philco radio from 1971 Ford F100 - by BILL - 12-05-2008, 03:53 PM
Re: Philco radio from 1971 Ford F100 - by Guest - 12-05-2008, 11:24 PM
Re: Philco radio from 1971 Ford F100 - by Guest - 10-30-2009, 01:40 PM
