pioneer sx1500td blowing fuse
#48
I tried powering amp without speaker,I just have one 4ohm. bookshelf speaker to test with.
Checked C15-C18 with ohm setting of meter in circuit I get a reading of like 1.504M on all of them.
V3 & V4 you said to minimum setting. I turned them full ccw.
Powered up and still drawing over 1 amp at 50V. I did have volt meter hooked to C13 + and it was reading 18volts when the B+ of amp was at 50 volts.
I unhooked the B+ to main amp and started taking volt readings at power supply again with outlet volts set to 117V. With the main amp out of circuit I can power up with amps staying .1v
I found something that might be the problem,not for sure.
I can get a AC reading on the B1 post which feeds the main amp. It is 25.40v ac. also can get reading on DC setting it is 54Volts.
I don't get any ac readings on the other B+ posts.
On the power board I have replaced all the E-caps, transistors Q1, Q2 ,Q3, the diodes D-2,3,4,5.
and the zener diode D6. I did remove D1- SB-3P and it tests good. I have not changed any resistors. Do you think something on power board is letting ac into the B+ to main amp? Your help is greatly appreciated.
pioneer sx1500td blowing fuse - by KCMike - 11-24-2014, 11:59 AM
RE: pioneer sx1500td blowing fuse - by morzh - 11-24-2014, 01:08 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 11-24-2014, 03:05 PM
RE: pioneer sx1500td blowing fuse - by morzh - 11-24-2014, 03:47 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 11-24-2014, 04:16 PM
RE: pioneer sx1500td blowing fuse - by morzh - 11-24-2014, 04:21 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 11-24-2014, 05:04 PM
RE: pioneer sx1500td blowing fuse - by morzh - 11-24-2014, 05:15 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 11-24-2014, 05:28 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 11-24-2014, 06:02 PM
RE: pioneer sx1500td blowing fuse - by morzh - 11-24-2014, 06:55 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 11-24-2014, 07:57 PM
RE: pioneer sx1500td blowing fuse - by morzh - 11-24-2014, 09:54 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 11-24-2014, 10:51 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 11-24-2014, 11:44 PM
RE: pioneer sx1500td blowing fuse - by morzh - 11-25-2014, 12:18 AM
RE: pioneer sx1500td blowing fuse - by KCMike - 11-25-2014, 08:51 AM
RE: pioneer sx1500td blowing fuse - by morzh - 11-25-2014, 12:22 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 11-25-2014, 01:28 PM
RE: pioneer sx1500td blowing fuse - by BrendaAnnD - 11-25-2014, 03:44 PM
RE: pioneer sx1500td blowing fuse - by morzh - 11-25-2014, 04:10 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 11-25-2014, 04:15 PM
RE: pioneer sx1500td blowing fuse - by morzh - 11-25-2014, 06:31 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 11-25-2014, 07:34 PM
RE: pioneer sx1500td blowing fuse - by morzh - 11-25-2014, 08:02 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 12-15-2014, 02:45 PM
RE: pioneer sx1500td blowing fuse - by morzh - 12-15-2014, 03:01 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 12-15-2014, 03:16 PM
RE: pioneer sx1500td blowing fuse - by morzh - 12-15-2014, 03:22 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 12-15-2014, 03:35 PM
RE: pioneer sx1500td blowing fuse - by morzh - 12-15-2014, 03:48 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 12-15-2014, 06:56 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 01-06-2015, 01:09 PM
RE: pioneer sx1500td blowing fuse - by morzh - 01-06-2015, 03:28 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 01-06-2015, 05:40 PM
RE: pioneer sx1500td blowing fuse - by morzh - 01-06-2015, 10:07 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 01-06-2015, 10:16 PM
RE: pioneer sx1500td blowing fuse - by morzh - 01-06-2015, 10:22 PM
RE: pioneer sx1500td blowing fuse - by morzh - 01-06-2015, 10:26 PM
RE: pioneer sx1500td blowing fuse - by morzh - 01-06-2015, 10:31 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 01-06-2015, 11:14 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 01-07-2015, 10:53 PM
RE: pioneer sx1500td blowing fuse - by morzh - 01-08-2015, 12:44 AM
RE: pioneer sx1500td blowing fuse - by morzh - 01-08-2015, 12:53 AM
RE: pioneer sx1500td blowing fuse - by KCMike - 01-08-2015, 10:35 AM
RE: pioneer sx1500td blowing fuse - by morzh - 01-08-2015, 11:59 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 01-09-2015, 07:34 PM
RE: pioneer sx1500td blowing fuse - by morzh - 01-10-2015, 12:04 AM
RE: pioneer sx1500td blowing fuse - by KCMike - 01-10-2015, 12:27 AM
RE: pioneer sx1500td blowing fuse - by morzh - 01-10-2015, 12:57 AM
RE: pioneer sx1500td blowing fuse - by morzh - 01-10-2015, 01:12 AM
RE: pioneer sx1500td blowing fuse - by KCMike - 01-10-2015, 10:01 AM
RE: pioneer sx1500td blowing fuse - by morzh - 01-10-2015, 10:56 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 01-11-2015, 03:46 PM
RE: pioneer sx1500td blowing fuse - by morzh - 01-11-2015, 07:08 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 01-11-2015, 11:05 PM
RE: pioneer sx1500td blowing fuse - by morzh - 01-12-2015, 12:23 AM
RE: pioneer sx1500td blowing fuse - by KCMike - 01-12-2015, 11:12 AM
RE: pioneer sx1500td blowing fuse - by morzh - 01-12-2015, 01:07 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 01-16-2015, 09:55 PM
RE: pioneer sx1500td blowing fuse - by morzh - 01-16-2015, 10:53 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 01-16-2015, 11:02 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 01-25-2015, 11:02 PM
RE: pioneer sx1500td blowing fuse - by morzh - 01-26-2015, 12:08 AM
RE: pioneer sx1500td blowing fuse - by KCMike - 01-26-2015, 05:14 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 01-26-2015, 06:15 PM
RE: pioneer sx1500td blowing fuse - by morzh - 01-26-2015, 07:28 PM
RE: pioneer sx1500td blowing fuse - by morzh - 01-26-2015, 07:34 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 01-28-2015, 12:57 PM
RE: pioneer sx1500td blowing fuse - by morzh - 01-28-2015, 01:40 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 01-28-2015, 03:00 PM
RE: pioneer sx1500td blowing fuse - by morzh - 01-28-2015, 04:16 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 01-28-2015, 10:34 PM
RE: pioneer sx1500td blowing fuse - by morzh - 01-28-2015, 10:56 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 01-28-2015, 11:32 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 01-29-2015, 12:13 AM
RE: pioneer sx1500td blowing fuse - by morzh - 01-29-2015, 04:31 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 01-31-2015, 04:21 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 01-31-2015, 06:09 PM
RE: pioneer sx1500td blowing fuse - by morzh - 01-31-2015, 07:16 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 01-31-2015, 08:03 PM
RE: pioneer sx1500td blowing fuse - by morzh - 01-31-2015, 08:12 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 01-31-2015, 08:57 PM
RE: pioneer sx1500td blowing fuse - by morzh - 01-31-2015, 09:22 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 01-31-2015, 10:37 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 02-01-2015, 08:55 PM
RE: pioneer sx1500td blowing fuse - by morzh - 02-01-2015, 09:19 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 02-01-2015, 10:09 PM
RE: pioneer sx1500td blowing fuse - by morzh - 02-01-2015, 10:25 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 02-01-2015, 10:55 PM
RE: pioneer sx1500td blowing fuse - by morzh - 02-02-2015, 09:24 PM
RE: pioneer sx1500td blowing fuse - by Eliot Ness - 02-02-2015, 09:36 PM
RE: pioneer sx1500td blowing fuse - by morzh - 02-02-2015, 10:33 PM
RE: pioneer sx1500td blowing fuse - by morzh - 02-02-2015, 11:41 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 02-10-2015, 01:57 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 02-10-2015, 08:14 PM
RE: pioneer sx1500td Fixed! - by KCMike - 04-03-2015, 05:41 PM
RE: pioneer sx1500td blowing fuse - by morzh - 04-03-2015, 06:00 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 04-03-2015, 09:37 PM
RE: pioneer sx1500td blowing fuse - by KCMike - 04-09-2015, 08:56 PM
There are currently 1387 online users. [Complete List]
» 1 Member(s) | 1386 Guest(s)
