02-09-2015, 07:34 PM
If you mean here:
[Image: http://www.philcoradio.com/images/phorum...770-43.jpg]
then you are correct. That is the antenna lead, and I am waiting until I get the restuffed electrolytics, one of which mounts in place just below the antenna terminal, to solder it into place.
The loose white and loose black wires will connect to the input electrolytic once it is in place.
Or do you mean here?
[Image: http://www.philcoradio.com/images/phorum...770-40.jpg]
It is in the correct position, on the band switch. I soldered it after I took the photo.
If you mean a different picture, please specify...thanks.
