Hallicrafters S-120
7 volts puts it safely inside the 125VAC max voltage.
I'm more concerned with the dial tracking. Getting the high end of each band aligned is doable with the trimmers. When I go to the low end of each band, the the coil slugs can't be adjusted enough to align with the dial.
Ex: Band 2 adjusting trimmers at 4.3 MC OK. When I try to adjust with the dial at 1.9MC, I can't get L2 and T2 to adjust below 2.3MC.
 I'm thinking about changing the cap values in these tank circuits.
Hallicrafters S-120 - by Eric T - 05-04-2015, 11:49 AM
RE: Hallicrafters S-120 - by David - 05-14-2015, 05:37 PM
RE: Hallicrafters S-120 - by Eric T - 05-16-2015, 08:03 AM
RE: Hallicrafters S-120 - by David - 05-16-2015, 02:50 PM
RE: Hallicrafters S-120 - by Eric T - 06-03-2015, 03:16 PM
RE: Hallicrafters S-120 - by David - 06-03-2015, 07:05 PM
RE: Hallicrafters S-120 - by Eric T - 06-04-2015, 12:55 AM
RE: Hallicrafters S-120 - by Eric T - 06-04-2015, 06:33 PM
RE: Hallicrafters S-120 - by David - 06-04-2015, 07:13 PM
RE: Hallicrafters S-120 - by Eric T - 06-05-2015, 10:16 AM
RE: Hallicrafters S-120 - by David - 06-05-2015, 12:59 PM
RE: Hallicrafters S-120 - by Eric T - 06-07-2015, 06:08 PM
RE: Hallicrafters S-120 - by David - 06-07-2015, 07:34 PM
RE: Hallicrafters S-120 - by Eric T - 06-08-2015, 02:43 PM
RE: Hallicrafters S-120 - by David - 01-15-2021, 02:49 PM
