02-17-2009, 09:40 PM
Hi Rich,
I didn't have any issues with coils when I did my set. I'd probably leave them alone unless I see something really bad.
The large filter can, I did house the new caps inside, but I DID NOT gut the entire can. I removed just enough to fit the new caps inside. The bottom ring of the can should slip off, also the bottom insulator/terminal strip should come out. Just remove aobut 1/2" of the tar, coil the wires or snip them short.
Solder the new caps to the bottom insulator, on the terminal strips. YOu will only need to put the insulator back in, then the metal bottom ring on and you're done. I have a couple of photos if you need to see them. I'll post as soon as I can.
I removed the tuning cap, and totally dismantled it, but it probably wasn't necessary. probably wouldn't do it again, just give it a good cleaning and lube.
Your grillework doesn't look bad at and and should be saved. Small donor pieces of veneer, glue and clamps is all that's needed. Just ight take some time, but it's worth it. You may have to brush stain or toner on pieces to make them match up, the grille is so thin though no none is looking to see the grain,
Will talk to you later,
Gary
Gary
