Jayce, You should make an offer. I don't think you'd be disappointed. It's a fairly straight forward set, and doesn't seem to have too much of the crumbling wire syndrome. At least not in my set. I only had to replace one or two wires. Caps are relatively easy to replace, save for two .05's buried against the side of the chassis under a coil. You'll have to install new rubber bushings for the push button assembly, which will most likely be loose and flopping around. The off/on push-button can be a little wonky and either stick on or not stay on. Contact cleaner will dry it out so I had to follow up with a squirt of WD-40.
Paul, I have the original XXL's in mine. They tested good and perform as they should.
42-345 - by NostalgiaRadioTime - 07-25-2015, 09:22 PM
RE: 42-345 - by VntgRads - 07-25-2015, 10:01 PM
RE: 42-345 - by NostalgiaRadioTime - 07-25-2015, 10:43 PM
RE: 42-345 - by tab10672 - 07-25-2015, 10:43 PM
RE: 42-345 - by Ron Ramirez - 07-26-2015, 08:11 AM
RE: 42-345 - by NostalgiaRadioTime - 07-26-2015, 11:49 AM
RE: 42-345 - by NostalgiaRadioTime - 07-26-2015, 11:51 AM
RE: 42-345 - by Arran - 07-27-2015, 02:50 AM
RE: 42-345 - by Paul Philco322 - 07-26-2015, 01:21 PM
RE: 42-345 - by Jayce - 07-26-2015, 02:44 PM
RE: 42-345 - by Paul Philco322 - 07-26-2015, 05:06 PM
RE: 42-345 - by NostalgiaRadioTime - 07-26-2015, 10:07 PM
RE: 42-345 - by tab10672 - 07-26-2015, 11:23 PM
There are currently 2748 online users. [Complete List]
» 2 Member(s) | 2746 Guest(s)
