Firestone 4A22
(08-13-2015, 06:30 PM)Radioroslyn Wrote:  One other thing I forgot to mention is that that transformer is a bit of an overkill as it is for a push pull output and is good for 8w. I would not use it as your set doesn't require one that big. You'd be lucky to 2w on a good day. If you have any junkers around with SE output stage that are not battery/portables I would snatch it up and use rather that the hammond.
I hooked it up,  I wanted to see if it would work or did I have other issues. it seems to play fine. Now I'm going to dig into the old one to see if I can fix it. and I do have some junkers in my shed so I'll look it see if I have one that is smaller. lots of veneer work to do so this will be awhile.
Thanks for the help.
Eric
Firestone 4A22 - by Eric - 08-12-2015, 06:32 PM
RE: Firestone 4A22 - by Radioroslyn - 08-12-2015, 08:39 PM
RE: Firestone 4A22 - by Eric - 08-13-2015, 09:50 AM
RE: Firestone 4A22 - by Radioroslyn - 08-13-2015, 06:30 PM
RE: Firestone 4A22 - by Eric - 08-13-2015, 07:51 PM
RE: Firestone 4A22 - by Radioroslyn - 08-13-2015, 08:03 PM
