Poor poor little National HRO Senior L76
#55
All the bits and pieces have arrived to make up the power cable. Have had the cable for a while now but needed the 4 pin plug and cover. Started at the 8 conductor cable wiring 2 sets of 3 wires for the heaters. I needed to use strippers as the cloth/plastic covering is tough can't do it with dikes I just end up cutting off some of the strands of wire. Got the plug end assembled now I need to scare up a grommet for  the chassis hole, don't have proper size.
Glued in the index marker. Front panel looks good! Also need to scare up a couple of 10mfd @ 25v or so for the two cathode bypass caps in the audio stages. Previous owner used 10@450v which is a little overkill and they are from '60's
OT RCA 6T71 1950 TV - by Radioroslyn - 06-13-2015, 10:19 PM
RE: Poor poor little National HRO Senior L76 - by Radioroslyn - 08-19-2015, 07:17 AM
There are currently 2829 online users. [Complete List]
» 5 Member(s) | 2824 Guest(s)
AvatarAvatarAvatarAvatar
