08-28-2015, 04:40 AM
Thanks Todd -- Yes I downloaded the Manual and instructions.
Per my Example
Main Switch Settings were E and 3
Filament Selector Switch Numbers were 1-5-7
Shunt was 22
The manual says to test for short by moving the 12 Switches one at a time from K to P Position EXCEPT the Ones noted as Filament Selector Switches. You then watch for the test light to come on that indicates SHORT.
My 12BE6 Tube lights the test light on Switch Number 4 - that supposedly indicates SHORT. BUT when I test for Quality - the same tube indicates GOOD.
So my question -- Is the tester functioning correctly ? because it indicates Short but tube tests good.
Shouldn't a tube with a short test Bad ?? Can a Tube with a short correctly test GOOD ?
Sorry if my first post was hard to understand -- I see the Board Software compressed my Lines from the Tube Chart making them hard to understand.
Thanks Again
PS - Question 3
3. Does a Brownish Darkened area inside the tube glass always indicate a bad tube or does it just happen because of heat and the Tube can still be good ?
Per my Example
Shunt was 22
Thanks Again
PS - Question 3
