my 37-61 the work...
I have ordered the proper
Re-Faux decals for my set. Today was a beautiful day to work outside, and to spray poly, so I decided to begin the prep of the cabinet for the photofinish. I first removed the trim piece at the bottom front, so the whole cabinet front was a single smooth surface. Then I began to block sand the old phtotfinish off with 180 grit sandpaper, followed by 220 grit as a finish sanding. I used a sanding block throughout to keep the surface as level as possible, especialy around the ribs and holes, although I did have to touch up around the speaker bolt holes by hand as they were slighly pulled into the surface. After sanding, I raised the grain with a rag dampened with water, let the surface dry again, and lightly sanded it smooth again. Then I shot it with the first coat of polyurethane. I will apply one more, and sand smooth before applying the decals when they come. Here are some pictures.
[Image: http://41.media.tumblr.com/d2af8980238ab...1_1280.jpg]
This is how it looked before any sanding
[Image: http://40.media.tumblr.com/1ee250e3006c0...2_1280.jpg]
This is after about an hour of patient sanding
[Image: http://40.media.tumblr.com/26d6fae76463c...3_1280.jpg]
The sanding finally done
[Image: http://40.media.tumblr.com/b8f10a439d975...4_1280.jpg]
The first coat of poly applied.
That is the work so far... stay tuned for further reports...
my 37-61 the work... - by mikethedruid - 09-27-2015, 04:00 PM
RE: my 37-61 the work... - by mikethedruid - 10-09-2015, 11:30 AM
RE: my 37-61 the work... - by OldRestorer - 10-09-2015, 11:53 AM
RE: my 37-61 the work... - by mikethedruid - 10-09-2015, 12:18 PM
RE: my 37-61 the work... - by mikethedruid - 10-11-2015, 04:58 PM
RE: my 37-61 the work... - by Ron Ramirez - 10-12-2015, 03:58 PM
RE: my 37-61 the work... - by mikethedruid - 10-13-2015, 04:50 AM
RE: my 37-61 the work... - by mikethedruid - 10-13-2015, 04:12 PM
RE: my 37-61 the work... - by mikethedruid - 12-10-2015, 06:46 PM
RE: my 37-61 the work... - by sam - 12-10-2015, 08:08 PM
Grundig 5088
There are currently 2510 online users. [Complete List]
» 2 Member(s) | 2508 Guest(s)
