Philco 60 Antenna Coil
Try this... 1400 on the signal generator modulated with the audio tone connected to antenna lug through the 200pf cap. Set radio dial at 140 and then move the dial around until you pick up the tone, maybe at 130 or maybe 150. move the radio dial off the tone slightly but in the direction to move the dial toward 140. Now try tuning the HF Osc trimmer to peak the tone. This moves it closer to 140. Repeat. (this is the rocking procedure they call for at 600 but I've used it at 1400 sometimes) You may run out of trimmer before you get to 140. Just a thought..
Philco 60 Antenna Coil - by Caperodder - 10-02-2015, 01:04 PM
RE: Philco 60 Antenna Coil - by Radioroslyn - 10-02-2015, 01:19 PM
RE: Philco 60 Antenna Coil - by Caperodder - 10-02-2015, 01:47 PM
RE: Philco 60 Antenna Coil - by Caperodder - 10-02-2015, 03:18 PM
RE: Philco 60 Antenna Coil - by Crist Rigotti - 10-02-2015, 02:54 PM
RE: Philco 60 Antenna Coil - by Caperodder - 10-02-2015, 03:24 PM
RE: Philco 60 Antenna Coil - by klondike98 - 10-02-2015, 04:38 PM
RE: Philco 60 Antenna Coil - by Radioroslyn - 10-02-2015, 05:11 PM
RE: Philco 60 Antenna Coil - by Caperodder - 10-02-2015, 05:41 PM
RE: Philco 60 Antenna Coil - by Caperodder - 10-02-2015, 05:39 PM
RE: Philco 60 Antenna Coil - by Caperodder - 10-02-2015, 05:45 PM
RE: Philco 60 Antenna Coil - by Radioroslyn - 10-02-2015, 06:03 PM
RE: Philco 60 Antenna Coil - by Caperodder - 10-02-2015, 06:07 PM
RE: Philco 60 Antenna Coil - by Caperodder - 10-02-2015, 06:21 PM
RE: Philco 60 Antenna Coil - by Radioroslyn - 10-02-2015, 06:30 PM
RE: Philco 60 Antenna Coil - by klondike98 - 10-02-2015, 06:54 PM
RE: Philco 60 Antenna Coil - by Caperodder - 10-02-2015, 07:02 PM
RE: Philco 60 Antenna Coil - by Radioroslyn - 10-02-2015, 07:34 PM
RE: Philco 60 Antenna Coil - by Steve Davis - 10-02-2015, 10:40 PM
RE: Philco 60 Antenna Coil - by Radioroslyn - 10-02-2015, 11:39 PM
RE: Philco 60 Antenna Coil - by Caperodder - 10-03-2015, 11:20 AM
RE: Philco 60 Antenna Coil - by klondike98 - 10-03-2015, 12:57 PM
RE: Philco 60 Antenna Coil - by Caperodder - 10-03-2015, 01:40 PM
RE: Philco 60 Antenna Coil - by klondike98 - 10-03-2015, 02:43 PM
RE: Philco 60 Antenna Coil - by Caperodder - 10-03-2015, 04:35 PM
RE: Philco 60 Antenna Coil - by klondike98 - 10-03-2015, 05:51 PM
RE: Philco 60 Antenna Coil - by Radioroslyn - 10-03-2015, 06:21 PM
RE: Philco 60 Antenna Coil - by Caperodder - 10-03-2015, 07:38 PM
RE: Philco 60 Antenna Coil - by Radioroslyn - 10-03-2015, 08:30 PM
RE: Philco 60 Antenna Coil - by Caperodder - 10-03-2015, 09:22 PM
RE: Philco 60 Antenna Coil - by Radioroslyn - 10-03-2015, 09:31 PM
RE: Philco 60 Antenna Coil - by Caperodder - 10-04-2015, 09:01 AM
RE: Philco 60 Antenna Coil - by klondike98 - 10-04-2015, 11:42 AM
RE: Philco 60 Antenna Coil - by Caperodder - 10-04-2015, 11:54 AM
RE: Philco 60 Antenna Coil - by Caperodder - 10-06-2015, 11:41 AM
RE: Philco 60 Antenna Coil - by Crist Rigotti - 10-06-2015, 02:54 PM
RE: Philco 60 Antenna Coil - by Caperodder - 10-06-2015, 03:00 PM
RE: Philco 60 Antenna Coil - by Crist Rigotti - 10-06-2015, 09:23 PM
RE: Philco 60 Antenna Coil - by Steve Davis - 10-06-2015, 05:38 PM
RE: Philco 60 Antenna Coil - by Caperodder - 10-06-2015, 06:00 PM
RE: Philco 60 Antenna Coil - by Caperodder - 10-07-2015, 08:03 AM
RE: Philco 60 Antenna Coil - by Radioroslyn - 10-07-2015, 05:08 PM
RE: Philco 60 Antenna Coil - by Caperodder - 10-10-2015, 10:35 AM
RE: Philco 60 Antenna Coil - by Caperodder - 10-18-2015, 03:58 PM
RE: Philco 60 Antenna Coil - by markmokris - 10-19-2015, 10:02 AM
RE: Philco 60 Antenna Coil - by Caperodder - 10-20-2015, 08:30 AM
There are currently 1576 online users. [Complete List]
» 2 Member(s) | 1574 Guest(s)
