Western Auto Radio Restore
Very nice!
Icon_clap Icon_clap Icon_clap
Uses a ballast tube?? I see it has a 68v 300ma heater string.
  Thanks Bob. I appreciate that.
 Terry it doesn't have a ballast tube. It had a BC resistor 17a -30 ohm 3watt & 17b- 106 ohms. 9 watt. I replaced it with two power resistors. First time I used  10 watts for both but they were very hot think I could fry an egg on the chassis. So I went with 2 power resistors that I bolted to the chassis 1-10 watt for the 3 watt & a25 watt for the 9 watt. It helped but still pretty darn hot.
  Here is the schematic. If you want to take a look.
http://www.nostalgiaair.org/pagesbymodel...023640.pdf
Stunning! Awesome!
I am back tracking on my resistors as the one that burned based on the old one's resistance was correct but another resi...osanders0311 — 05:34 PM
"So you can see how Important it is to identify parts with the schematic, especially when you have multiple parts o...osanders0311 — 05:23 PM
Arran. As always, the information you have provided is very valuable to me. Thank you. Yes, it is a Canadian Philco 316A...RadioSvit — 04:04 PM
Best to use the one from the library on this site, then when you refer to part 30 we know which part you are referring t...RodB — 03:32 PM
52-942
Welcome to the Phorum, Ken! The included schematic for your set is located in the Philco Library at the bottom of our Ho...GarySP — 03:13 PM
Video Source for Predicta
You can also source a used VCR and use that as a modulator to feed your DVD source into.TV MAN — 02:57 PM
52-942
Just received my 52-942. Its a handsome set. When I opened the back to examine it I noticed there are not connecting wir...Ken Arroyo — 02:54 PM
"Your radio tubes get these voltages from the power transformer secondary windings. The A voltage is supplied by th...osanders0311 — 01:40 PM
Please correct me if I am wrong, while working on this radio I noticed under the chassis where the bottom of the tubes p...osanders0311 — 01:28 PM
"BTW there's a 2.2k resistor from B+ to one of the XXL tubes so you have to identify those resistors before you rep...osanders0311 — 01:04 PM
There are currently 892 online users. [Complete List]
» 1 Member(s) | 891 Guest(s)
