Philco 70 tuning backward?
So elaborate what are you seeing?? Pic is a little out of focus and doesn't show the whole stator if that is what the issue is. You are missing the rear bail clip??
Terry, I think what Bill is referring to is the last set of stator plates were installed backward.
M R Radios   C M Tubes
I think ur right! Didn't notice it. That pretty odd or maybe there a SB on it.
(10-17-2016, 09:28 PM)Radioroslyn Wrote:  I think ur right! Didn't notice it. That pretty odd or maybe there a SB on it.
Yes that was backward! I flipped it and everything was back to normal.I wish the picture was clear .I had to crop it to get it to attach. I think if I was standing behind the radio when I worked on it I might have seen it.last night i was able to pulling am740 strong and right on the dial. 1420 &1230 during the day also.So I still have some things like a new line cord to add .But done to the point where I can move on mostly ! Next I have to decide refinish or not.Since I have a replacement grill most likley I will refinish . I will try not to put it in backwards.
YOU,,,would think ,,that the Blades,,,would have been in a bind,,,against the shalf,,,,and would nor turn,,
It looks like there are marks on the plates where the shaft had been rubbing.
(10-19-2016, 07:14 PM)Steve Davis Wrote:  It looks like there are marks on the plates where the shaft had been rubbing.
Steve yes that is where the shaft was riding . It was hard to put the back clip on.Should have known right there. After a few days of playing on and off I am happy with the radio.Not really missing the lack of Avc on this. Works ok , maybe even better than just good. For those wondering about coil ohms take a look back on this post.Can's say they are perfect but with all capacitors and resistors to print value they work. On to the cabinet ,thanks again to all!!!
Bill
