Rare zenith 6s137 restore
Hi Fred,
I get things to work, but what you, Russ, RadioSvit and many others on the Phorum do with cabinet and chassis finish restoration is absolutely stunning! I echo the need to appreciate history to keep these hitoricaal pieces alive and well!
All of these restorations are two projects. The chassis and the cabinet. You're done with the chassis.
I would keep the nostalgic charm and not strip the cabinet unless there is major cabinet work involved. Remove the hardware and grille cloth. I would decide what stains I would use, sand it with 150 grit then 220 grit. Use tack rag then clean with oms then lacquer thinner. All is smooth and clean. Apply the stains, darker first and you can mask off where the lighter stain goes if you feel better. After dried, buff with 0000 steel wool to smooth the surface then spray on clear lacquer, any finish you want. You may want to patch up the chipped veneer before starting, but leave the nicks and cigarette burns alone. They are beauty marks; after all that beauty is how old? Do you want it to look new? If yes, then before you start strip the cabinet.
Show us the progress. Just do it then you can say you did.
Peter; I found an old thread on the ARF, I was wrong about when Rogers took over DeForest Crosley, it looks like it wa...Arran — 06:15 AM
Thank you Arran, this is very interesting information. With your permission, I will definitely use it when I make a vide...RadioSvit — 04:14 AM
Peter; For a start your DeForest Crosley 6D632 was a 1936-37 model, and I believe it had six tubes, and 3 wave bands,...Arran — 03:07 AM
AES type of Battery Eliminator has hum in B+
This is interesting, they actually designed the B+ side with some form of voltage regulation, I think? Most of the B+ su...Arran — 02:21 AM
They are trying to use a regulator. Essentially it is an LDO schematic. LDOs are supposed to greatly reduce ripple, so t...morzh — 12:11 AM
So, I just built a 90 volt 40ma battery eliminator for a farm radio and had to use 1000 mfd for the input filter cap to ...RodB — 10:31 PM
Caps of 1,000 uF 250V are about $7 in Mouser. C1 could be increased. A NTC inrush limiter could be employed to limit t...morzh — 10:24 PM
Bruce B — 09:41 PM
Bruce Could you post the schematic if this power supply?morzh — 09:31 PM
Hello All, I have built a battery eliminator using the most popular AES K101a. Using plans and all the AES parts  order...Bruce B — 09:27 PM
