41-608 code 122 Capacitor Questions
A-ha, see it now. Green wire to 8uF, blue and red to 12 and 16 uF respectively.
If I understand the schematic right the negatives of both 21A Red and 21B Blue go together to the yellow wire. Please correct me if I am wrong
Look like the negative of the red is going between the 28 and 26 ohm candohm and the blue is tied to the 780 ohm? which is before the 268 ohm but the schematic is too blurry.
But yes the the both negatives are going to yellow but must be wired correctly per the schematic.
Hoping someone can help me out here.  New to the Phorum and just finishing recapping of my Philco 41-608.  I changed the bakelite block capacitors #81 with the two safety capacitors that are recommended.  I also just changed the filter capacitors to 21 10uf, 21A 22uf, & 21B 10uf.  I believe I have the 5 wires that were coming out of the can correct.  Attached is a drawing I made.  Can anyone confirm I have this right.  I still have a nasty hum.  Any help is greatly appreciated.  Thanks
Restoring Philco 96
Restoring Philco 96
Restoring Philco 96
My Philco 37-116 Restore
I managed to open up the Expander Unit and replace the grid cap wires. Tested the connections found they looked good and...dconant — 12:19 PM
610B Oscillator Questions
I've included a picture of the 'actual' schematic I created. I double checked several times and it appears to be accur...Tubester — 09:26 AM
First Radio restoration
Hi, welcome. I did a 40-130 a few years ago. I was very surprised at how well it performed. Just take care with that sp...Stan the Man — 07:20 AM
Restoring Philco 96
Situations of the like are not pleasant. Life is inevitable. Best of luck to you. I have two 76 chassis, in different ...Stan the Man — 07:12 AM
There are currently 2006 online users. [Complete List]
» 3 Member(s) | 2003 Guest(s)
