fused 2 or 3 prong male plug ends 120v US
i noticed some odd ball tags on this hobby lobby cord like one that said "use as temp only wiring for less than 60days".
they claim the stranded wiring is 22awg but i measure .040 inches which is 18awg
the insulation is rated to be 105degC.
there is no UL marking so im thinking they "china" found a loop hole in order to supply a polarized cord with on off sw & a lamp socket and lamp without testing.
it came with a couple spare 5amp mini fuses , a 25watt 120v bulb so.... im sure it will be fine for an antique lamp i am doing.
Perhaps they are trying to discourage people from permanent use of extension cords. Wnen we arrived at my wife's parents house, the basement, and connections to outbuildings were teaming with extension cords of every type and capacity running thihs way and that, daisy chained - you name it, I saw it! Shocking...
Mostly this was in place of running proper electrical service, and it was truly horrifying to me, but people do crazy things and get away with it most of the time... I can't understand how there was not a fire or an electrocution.
Rogers Majestic R-646
Thanks RpdB I don't think there's much difference with interstage transformers of different models other than dimersion...Vlad95 — 03:27 PM
Vlad; I looks like your set has the same problem that mine did, both a bad output transformer, and a bad audio inters...Arran — 03:21 PM
Ouch! Not often the secondary takes a hit. Wish there was a better solution. I have a good interstage transformer but it...RodB — 02:59 PM
By the way, the bypass you suggested is a rare solution in some circuits. For example, this schematics solution is used...Vlad95 — 01:43 PM
No, you are wrong, because you did not know the details. Unfortunately, only ONE winding out of six is intact in both t...Vlad95 — 01:14 PM
The output 45s are still in push-pull because the transformer secondary winding is still in the grid circuit providing o...RodB — 11:52 AM
Thanks RodB for the help. But this is not a real solution to this situation, not even a temporary one. Because the firs...Vlad95 — 11:34 AM
I was going to check the voltages as you suggested and hooked it up to my dim bulb. It appears I have a short. The bul...bobclausen — 10:34 AM
So, here's Prince on stage halfway through Purple Rain when he stoops down to his tech and says "Rod, pull out that...RodB — 09:17 AM
There are currently 1028 online users. [Complete List]
» 1 Member(s) | 1027 Guest(s)
