42-1008 code 121
unfortunately not
I'm not entirely sure of the state of the tubes, I have a knight 600b tube tester but it doesn't list any of these tubes on the scroll
Good time to find one. Doesn't have to be anything fancy but it allow us to inject a signal and hear what stages are working. You can go thru and measure the pin voltages on all the tubes (5Y4 is ok) and see if there are any anomalies.
I'll see about acquiring one, and in the meantime i'll test and record pin voltages for each tube. As you can tell I'm new to radio's and I really appreciate the help you given me.
Icon_thumbup
Ive got a heathkit sg-8 on the way
What kind of voltage should i be seeing out of the output transformer?
THe simple way to check the voltages at the transformer is to measure the plate pin of the output tube (on the 41's it's pin 2) So measure the voltage from pin 2 to the chassis. On both tubes should see abt 250vdc. Then measure the voltage on the screen grids (pin 3) should see about the same. One of the screen grids is going to be a bit lower in voltage as it has a 3,000 ohm resistor in series with the hv source.
nothing on those and the center tap is dead also... Looks like I'm back in the same boat. Do you know of a new tx i can get for this?
To be clear I'm speaking of the output transformer.
If the power transformer was bad (now) you wouldn't have 600vac from pin 3 to pin 5 on the 5Y4.
Power transformer:
3 and 5 (yellow)=637 ac volts
7 and 8(blue)=370 dc volts
on the 5Y4
Between black and black coming off the PT 6.5 volts ac
yellow-green center tap= o volts to chassis
Output transformer:
0 volts VDC from pin 2 on 41 tube to chassis
And pin 3 of the 41 tubes??
I got high tech and set up a thermal imaging camera on the chassis as I slowly wound up the variac, and found the #77 resistor on the far left side was what was getting hot and smoking.
I found 2- 470k resistors that where out of spec by a little over 20% that go to the bias resistor, I'm hoping that is my issue. What wattage resistor should those be replaced with? I don't see a rating on the schematic. 2 watt?
To follow up on this post, There was a short in the field transformer wires, and a resistor that was not connected. Set is now receiving. Thank you Terry!
-rperry
Hi SQ55, A strange issue indeed!  Just so I have you straight, on a dim bulb you get normal operation after the set war...MrFixr55 — 12:44 AM
schematics
I think mseno is talking about cap# 27 which is a multisection but in a paper tube. In cases like that I've usually be ...klondike98 — 11:25 PM
schematics
Ohrenet  :roll: For their price I would chase a fly in a field.  :twisted:Vlad95 — 11:21 PM
A bit more work on the Motorola. I got the repro battery together right up until I realized the snap clips on the top o...klondike98 — 10:45 PM
schematics
Often restuffed. If a twistlock, Hayseed Hamfest makes modern replacements. morzh — 09:18 PM
schematics
Looking for a multi-sectional 8+16 mfd cap. Can't find any suppliers that carry it.mseno — 08:45 PM
schematics
Richard, thanks so much, greatly appreciatedmseno — 08:39 PM
I'm starting to restore a Philco 16X, I need spare parts. Please, help me find ...
Peter; I believe that the "A" suffix means that it has as 25 cycle power transformer, not all Canadian sets...Arran — 07:05 PM
I am back tracking on my resistors as the one that burned based on the old one's resistance was correct but another resi...osanders0311 — 05:34 PM
"So you can see how Important it is to identify parts with the schematic, especially when you have multiple parts o...osanders0311 — 05:23 PM
