philco model 84
I unhooked wire from the if to grid of second detector and put a 4 meg resistor to ground and a .047 cap and used a second radio to drive the audio amp and there was no distortion. must be from second detector or first detector. some station are and some are not our local station is not distored.
I have -16.5 volts on 42 grid also tried a pm speaker sounds the same 250 volts on screen grid 233 volts on plate of 42
I will work on it somemore Thursday.
Update on distortion after some more voltage checking screen voltage on second detector (77 tube )was 27 volts should be 23 didn't think 4 volts would matter but it did added 440k resistor from screen to ground to lower screen to 23 volts help distortion on most stations.
How many amps a man can have? I say, as many as the space can hold.morzh — 10:01 AM
Value of capacitor
>>>It currently has an .005 1000 volt electrolytic that is at least 40 years old. That needs to go. There i...morzh — 10:00 AM
One irritating little amp - VM 557
The VM amps were kinda weird, but as you say, they did work well until they didn't. I just got a bag full of new tube so...TV MAN — 08:56 AM
I have a pair of Mk3 Dynas and they always sounded great with plenty of punch. 6550 is the same as a KT88 except usually...TV MAN — 08:45 AM
philco predicta
As Mr. Fix says, this is a live chassis so without an isolation transformer, it can be dangerous to work on. There's goo...TV MAN — 08:33 AM
Value of capacitor
If this helps you sort it out just remember 10,000 mmfd or pf = .01 mfd. So 5,000mmfd = .005 mfd.Radioroslyn — 04:23 PM
Value of capacitor
OP here- the parts list calls for an .005 1000 volt mica. It currently has an .005 1000 volt electrolytic that is at lea...bridkarl — 02:09 PM
Value of capacitor
Maybe it's one of those paper caps that is wrapped in a mica-lookiing case.RodB — 01:51 PM
Value of capacitor
I also was wondering what the post about using polarized caps had to do with the subject? The cap is 5nF, does not exis...morzh — 10:22 AM
Value of capacitor
The OP stated that there is an electrolytic in the circuit in place of the coupling cap and wondered what effect it has....RodB — 09:53 AM
There are currently 2050 online users. [Complete List]
» 1 Member(s) | 2049 Guest(s)
