What model is this Philco Transitone?
Icon_confused Well, having recapped the entire radio, replaced three of the five tubes (the other two glowed a little so I figured they were still good) and replaced some of the wiring, all I get now is a constant low hum that is unaffected by turning either the volume or dial controls. I suspect that some of the resistors need replacement, but I don't see much written about replacing the resistors in vintage radios. What would be the symptoms of a radio with bad resistors?
Thx Arran & Gary. Yes its super crowded in the chassis and I've debated whether to try to restuff caps or not. I t...klondike98 — 07:40 PM
That's got to be one of the tightest conglomeration of components I've ever seen! I wonder how the line workers felt bu...GarySP — 05:46 PM
Bob; I think that the Phillips was actually manufactured in Canada, though they may have imported many of the compone...Arran — 02:28 PM
I've started replacing the electrolytic caps now. As Arran mentioned, they are housed under a metal strap. Here's a ph...klondike98 — 12:22 PM
Thank for that info Arran! Very interesting. Phillips and Motorola must have made some type of marketing deal back then....klondike98 — 11:49 AM
46-1213 Schematic Question
Good idea on the fuse. These old transformers need extra protection.RodB — 10:02 AM
Hello Larry, Well, anyway I can contest about noisey grounds in my living room when I am using one outlet in my house a...radiorich — 08:03 AM
RodB & MrFixr55, Thank you both for the great replies at my questions, I appreciate the help very much.  As suggest...MissouriLarry — 07:04 AM
Rogers Majestic R-646
Vlad; I also have an R-646 but it's in rough shape, the chassis is complete, but the speaker is missing, and the cabin...Arran — 01:06 AM
Hi Larry, Back when this set was built, they did not use polarized power plugs. Technically, your chassis is sittin...MrFixr55 — 12:11 AM
