I really want to understand old radios.
Threads: 9
City: Oregon
(03-10-2012, 01:13 PM)codefox1 Wrote: Old Police band is useless. Get rest of set to work.
Thanks, Thought so, since it is 1700 KC up.
Set does work, just weak. I was just thinking out loud that if I can't glue the band selector back together to just by-pass it to AM.
lyle
I may not be very good, but I'm slow.
Threads: 54
(03-10-2012, 12:58 PM)lyle Wrote: (03-10-2012, 08:44 AM)7estatdef Wrote: (03-10-2012, 12:55 AM)TA Forbes Wrote: Hello, Lyle: I would be glad to offer any assistance that I can, but I must tell you that there are MANY fellows here on the Phorum that are WAY better radio guys than me. What I especially like about this site is the people that contribute to it. Here you have a valuable resource for radio questions.
I'm definitely NOT an expert on wimmen, as two divorces and numerous failed relationships will attest. In fact, I don't even call my ex-wives by their name any more, I just call 'em both "plaintiff."
So wimmen questions are best left for others.
I discovered that the volume control I need was used in several Philco sets, including the 20, 46, and 70. I also discovered that the 1st IF transformer was open, so now I am searching for one of these too.... Hey Tom
I can probably help you out with the volume control from a mdl 20.
Terry No worries, TA, I don't know enough to ask hard questions. I made a discovery of my own. This Philco 60 has a break in the phenolic wafer of the Band Selector. It is now in two pieces on my bench. It's been suggested I use super glue. Finding a replacement probably won't be easy.
If I can't fix it maybe I can just by-pass it to the AM band. I don't think there really is a police band left.
lyle
You could bypass the switch to make it work but on these sets the lower end of the old police band is the top end of the AM broadcast band. The old AM broadcast band stopped at 1500 KC, the current one goes to 1700 KC, so to get stations above 1500 you need the police band working on a Philco 60.
If you want to learn about old radios there is a book out there called "Elements of Radio Servicing" by Marcus and Levy, it's out of print but there are a lot of copies still out there.
(This post was last modified: 03-10-2012, 09:50 PM by Arran.)
Threads: 9
City: Oregon
(03-10-2012, 09:37 PM)Arran Wrote: (03-10-2012, 12:58 PM)lyle Wrote: (03-10-2012, 08:44 AM)7estatdef Wrote: (03-10-2012, 12:55 AM)TA Forbes Wrote: Hello, Lyle: I would be glad to offer any assistance that I can, but I must tell you that there are MANY fellows here on the Phorum that are WAY better radio guys than me. What I especially like about this site is the people that contribute to it. Here you have a valuable resource for radio questions.
lyle
Thanks Arran. I have a copy of 'Essentials of Radio' by Slurzberg & Osterheld, printed in 1948. Got it on ebay. Will look for 'Elements...'
I did repair the band selector switch today with superglue and epoxy. What a relief.
Thanks again,
lyle
Threads: 92
City: Clayton, NC
The police band on a 60 is 1.5 MHz to 4.0MHz. Arran is right, the top end of modern AM broadcast band is "police band" on your set.
You can still pick up some "interesting" shortwave programs with the police band available on your model 60.
Threads: 9
City: Oregon
OK, I'll bite. What do you mean by "interesting?"
lyle
Threads: 92
City: Clayton, NC
Some foreign french and spainish programs, some Christian broadcasts including one fellow who claims to be a modern day prophet, (I am a Christian, FYI), Voice of America, and a broadcast that is Conspiracy Theory oriented.
Your antenna system will detirmine what you are able to pull up.
Threads: 9
City: Oregon
Well, TA, I do have a 90 foot long wire. I get Australia and Romania pretty easily on my home-brew 1-tube Regen. So, it should be interesting. Hoping I get the conspiracy Theory one. Have a SONY SW, but haven't gotten anything that interesting. I'm not a Christian, quit the Catholic church at age twelve on the day of my confirmation. That's the day Catholics confirm their faith. Ironic huh?
lyle
Threads: 9
City: Oregon
Wilco, Codefox1
lyle
Rogers Majestic R-646
Transformers rewind?
It's very easy!
If you don't have round eyes 8-)
Vlad95 — 01:55 PM |
Help with Supreme 599
I found a broken wire from the end og the 300 ohm line adjust to the transforner but i dont think its needed. The transf...daveone23 — 11:43 AM |
Philco 38-10 Tuning Condenser
RodB
I have been using pure Vaseline for a long time for thick lubrication of home radio devices. The main reason is t...Vlad95 — 10:58 AM |
Vlad, your comment about Vaseline brought a thought. Does anyone know the long term affect on using silicon grease on t...RodB — 10:34 AM |
Arran, didn't notice the specifics for the caps. What's the code going to get me? I'm working on restoring a Philco 50-9...RodB — 10:26 AM |
I managed to get the gears lined up and the springs back in. Much easier than it thought. Putting a thin wire down insid...dconant — 09:52 AM |
Rod, Mrfixr55 and everyone else thank you very much for all your help with this radio thus far. Today will be more testi...osanders0311 — 09:26 AM |
Thanks for the reply Vlad95. I can't even see the balls let along try to remove them. The grounding forks are going to p...dconant — 08:03 AM |
Vlad;
Yes it's very similar, Motorola obviously wanted to get the most use they could out of the dyes used to stamp o...Arran — 11:18 PM |
Rod;
I that 27 pf 1 kv capacitor you found a C0G ceramic cap or just a regular ceramic cap? A different topic but I t...Arran — 11:16 PM |
There are currently 683 online users. [Complete List] » 2 Member(s) | 681 Guest(s)
